xjustinx Posted May 21, 2017 Share Posted May 21, 2017 Has anyone fitted AN fittings on their sending unit? I know you could use compression fittings but with that you would have to cut the tubes on the unit. I kinda would like just to use an adapter if that exists since good sending units for the Comanche are hard to come by. Would hate to destroy a good one just experimenting. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 21, 2017 Share Posted May 21, 2017 I think this is what you are looking for- http://www.ebay.com/itm/Russell-640863-Adapter-5-16-Fuel-Injection-Fitting-LT1-LT4-LS1-Pressure-/172591843255 Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted May 21, 2017 Share Posted May 21, 2017 There is no raised portion on the lines coming out of the sending unit that the plastic clip will hold onto. Just out of curiosity, why are you wanting to change to those fittings ? I've never had one leak before... Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 21, 2017 Share Posted May 21, 2017 The real question is- why not? I assumed they were quick-connects, which suck. Get a steel adapter and silver solder them on, they can always be removed. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted May 21, 2017 Share Posted May 21, 2017 The real question is- why not? I assumed they were quick-connects, which suck. Get a steel adapter and silver solder them on, they can always be removed. Because if it isn't broke don't fix it . The OP doesn't want to ruin the good sending unit by cutting it up, so I'm answering in regards to that . The ends of the lines are mushroomed on the sending unit to keep the rubber hose on once its hose clamped on preventing any steel adapter from sliding on . Not to mention if the sending unit was rotted out ( the only reason I see that it would need to be replaced ) the lines would be weak and not hold up to soldering anyhow . Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 21, 2017 Share Posted May 21, 2017 The only reason to get AN is to go braided, if that's his desire, there are clamp-on ends for the braided steel. Then go on with braided or a mix of braided/hard line with AN fittings. Some of us do things just to do them. Link to comment Share on other sites More sharing options...
xjustinx Posted May 21, 2017 Author Share Posted May 21, 2017 Just being curious really. I just like over building my truck. Link to comment Share on other sites More sharing options...
