intermittent Starting issues
My Comanche has been having odd starting issues lately. It will run and start fine for weeks, then occasionally I will go to start it and it will do nothing. I will have interior lights and headlights, sometimes not the brightest, however I will have nothing when I turn the key. But, if I wait a few minutes or even noticed that if I unplug the battery and plug it back in it will fire right up. Does this sound like a grounding issue? I am going to follow cruisers tutorial on redoing the ground wires. Anything else I should look for? Thanks in advance. BTW its a 90 4.0 renix 2WD
Sorry its a 90 with a renix 4.0 2WD
Well, not my area of expertise. Doing cruisers grounding tips is the best thing to start with. If that doesn't do it, I'd get a multimeter the next time it doesn't start and check voltages at sensors. Not only will this verify proper voltage but it will serve to refresh your connections as well.
Sent from my SM-G930T using Tapatalk
