Jackrabbit41 Posted April 10, 2017 Share Posted April 10, 2017 So I'd love to get some updates doors for my manche. Can I put in powered doors without doin an entire 97 front clip swap? Link to comment Share on other sites More sharing options...
Siopposition Posted April 10, 2017 Share Posted April 10, 2017 If u put in the dash harness and change the door striker I think you can, but I think u have to use the newer door panels as well. Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
Dzimm Posted April 10, 2017 Share Posted April 10, 2017 Does it currently have power doors? If so you can do this but there is a lot of cutting and splicing of wires. Nothing plugs directly in AFAIK. As far as adding power to a non power truck, idk how that would work or if the trucks wiring would be set up for power doors at all. Link to comment Share on other sites More sharing options...
Dzimm Posted April 10, 2017 Share Posted April 10, 2017 If u put in the dash harness and change the door striker I think you can, but I think u have to use the newer door panels as well. Sent from my SAMSUNG-SM-G891A using Tapatalk For the 97+ doors you do have to change the door striker over (search 97+ swaps for info) and you would have to use the 97+ door panels because the doors are completely different on the inside. The door wiring harnesses cannot be swapped between 97- and 97+ doors either since the lengths of wire are different. Link to comment Share on other sites More sharing options...
cody4359 Posted April 11, 2017 Share Posted April 11, 2017 Dunno if you have pwr or not, but maybe look into 97+ with manual windows for s simple swap. Pretty sure I did a write up about 5 years ago for the striker swap. Basically, drill out the spot welds and remove the plate that captures the nuts. I took some flatbar, measured the hole pattern for the new striker, drilled, put bolts in with new striker and welded nuts on the back. Measure/eyeball where you want it on the door jamb, drill 2 holes, and fiddle around with enlarging them til you get it where you want. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
