NC Tom Posted April 8, 2017 Share Posted April 8, 2017 So I have found a trans that I think/hope I can use for my 88. It's in a 90 Cherokee. I know the trans were changed during that model year. How can I tell if the spline count is correct without opening the case? Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted April 8, 2017 Share Posted April 8, 2017 I think the 90 is the 21 count spline (87-90) and 91 up is the 23. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
NC Tom Posted April 8, 2017 Author Share Posted April 8, 2017 I think the 90 is the 21 count spline (87-90) and 91 up is the 23. Sent from my iPhone using Tapatalk Pro Thanks. Right, but I thought they changed that midway thru 90. I'm wondering if I'm right about that and if there is a number or code on the exterior of the Cherokee that confirms it. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted April 8, 2017 Share Posted April 8, 2017 When did a parts search they didn't show a mid year difference. Usually pretty accurate far as that goes. From the searches I've done everybody says 90 is a 21 spline except for ax15 which is 23 spline. As long as was built before August 1990 it still a 1990 model after August its a 91 Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
cruiser54 Posted April 8, 2017 Share Posted April 8, 2017 I think that midyear stuff is crapola. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 8, 2017 Share Posted April 8, 2017 I think that midyear stuff is crapola. Surely, this is the one he is looking at- https://boone.craigslist.org/pts/6019005508.html The seller doesn't even know what year it is. But, for $150...........your core on a rebuilt will be that.........or..........$150 for a 23 spline TC...............you are still at $300 for a trans/TC combo. OP, go look at it, count the spline. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 8, 2017 Share Posted April 8, 2017 AW4 output splines 21 spline is about 1.08” diameter or 27mm 23 spline is about 1.22” diameter or 31mm Link to comment Share on other sites More sharing options...
NC Tom Posted April 8, 2017 Author Share Posted April 8, 2017 I think that midyear stuff is crapola. Surely, this is the one he is looking at- https://boone.craigslist.org/pts/6019005508.html The seller doesn't even know what year it is. But, for $150...........your core on a rebuilt will be that.........or..........$150 for a 23 spline TC...............you are still at $300 for a trans/TC combo. OP, go look at it, count the spline. Nope. Not that one. Although I did contact that guy and it won't work. It's newer than 90. Link to comment Share on other sites More sharing options...
NC Tom Posted April 8, 2017 Author Share Posted April 8, 2017 I think that midyear stuff is crapola. Okay, Cruiser54 school me. The guy has a couple of trannys. He has a 2wd that is in good shape, however, it's my understanding that you cannot convert 2wd to 4wd, so that's not an option. He has a 90 that stopped working. the mechanic said it was a bad pump? IDK what that means as a potential donor. He has a 95 too. That one can work if I swap the transfer case too, correct? Is it that easy-peasy? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 8, 2017 Share Posted April 8, 2017 I think that midyear stuff is crapola. Okay, Cruiser54 school me. The guy has a couple of trannys. He has a 2wd that is in good shape, however, it's my understanding that you cannot convert 2wd to 4wd, so that's not an option. He has a 90 that stopped working. the mechanic said it was a bad pump? IDK what that means as a potential donor. He has a 95 too. That one can work if I swap the transfer case too, correct? Is it that easy-peasy? Yes it is. Forget the one with the bad pump. Install the trans and transfer case. Sell your old transfer case on craigslist and your old tranny to a trans shop as a core for $25 to $50. Link to comment Share on other sites More sharing options...
NC Tom Posted April 8, 2017 Author Share Posted April 8, 2017 I think that midyear stuff is crapola. Okay, Cruiser54 school me. The guy has a couple of trannys. He has a 2wd that is in good shape, however, it's my understanding that you cannot convert 2wd to 4wd, so that's not an option. He has a 90 that stopped working. the mechanic said it was a bad pump? IDK what that means as a potential donor. He has a 95 too. That one can work if I swap the transfer case too, correct? Is it that easy-peasy? Yes it is. Forget the one with the bad pump. Install the trans and transfer case. Sell your old transfer case on craigslist and your old tranny to a trans shop as a core for $25 to $50. Alright. He has a transfer case. I'm out of my element here. What should look for in a used case and how much should I pay for a 90s case? Link to comment Share on other sites More sharing options...
NC Tom Posted April 11, 2017 Author Share Posted April 11, 2017 We'll I was wrong. He does not have a transmission to match the case. He's asking $150 for the case. Is that typical? And, if can get a transfer case and tyranny for $300, is that a good deal? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 11, 2017 Share Posted April 11, 2017 We'll I was wrong. He does not have a transmission to match the case. He's asking $150 for the case. Is that typical? And, if can get a transfer case and tyranny for $300, is that a good deal? Prices are great. Risk seems high with this guy though. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted April 12, 2017 Share Posted April 12, 2017 That's not bad price on the transfer case. What I'd call high fair but it's been years since I looked for a 21 spline np231 ($75-150 - years ago) 23 spline np231 that is where the lower price sitting about a year ago. ($100-250).You can do better sometimes but it depends on where you are. I've been looking for a spare 91-96 aw4 4wd off and on for years $100-200 is a good price if you can find it. I'm Not sure what the guy with the parts is doing, I'm kind of leery his stock keeps morphing. If his transmission is 1990 it should work with your transfer case just fine. If it's 1991 up you'd need to swap the gear for the right one or the transfer case to match the transmission. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
