Tex06 Posted May 18, 2017 Share Posted May 18, 2017 I'm starting to have this gear engagement or lack there of problem myself lmdo hahahahahahahahahahahahahahaha woooo so when i stop at stop sign/light if i don't down shift into first before completely stopping it is a pain to get it into gear unless i shift into any other gear first and then into first haha or if i engage/disengage clutch ever so skillfully(up&down 10 times slowly) it slides in.its has been like that since obtaining said comanche come to think of it so wasnt sure if that is on me not knowing how to drive a manual or on ol mud bud itself haha so i guess its the flywheel and what have yas there Sent from my LG-V410 using Tapatalk Same issue I had. Real PITA, although I got real good at 2nd gear take-offs and rolling stops, lol. Get ya a jy AX-15 and swap 'em out or pull and rebuild if that's an option. Your 1st gear synchro is likely shot. Link to comment Share on other sites More sharing options...
offthepavement Posted May 18, 2017 Share Posted May 18, 2017 I'm starting to have this gear engagement or lack there of problem myself lmdo hahahahahahahahahahahahahahaha woooo so when i stop at stop sign/light if i don't down shift into first before completely stopping it is a pain to get it into gear unless i shift into any other gear first and then into first haha or if i engage/disengage clutch ever so skillfully(up&down 10 times slowly) it slides in.its has been like that since obtaining said comanche come to think of it so wasnt sure if that is on me not knowing how to drive a manual or on ol mud bud itself haha so i guess its the flywheel and what have yas there Sent from my LG-V410 using Tapatalk Same issue I had. Real PITA, although I got real good at 2nd gear take-offs and rolling stops, lol. Get ya a jy AX-15 and swap 'em out or pull and rebuild if that's an option. Your 1st gear synchro is likely shot. i have still some teeth left on first gear ☺ if i play with the clutch just alil it will pop in or if I'm stopped and i shift into second and then it lets me shift into first like brand new first gear is on its way out though i just know it Sent from my LG-V410 using Tapatalk Link to comment Share on other sites More sharing options...
1987Comanche Posted May 25, 2017 Share Posted May 25, 2017 I wanted to check in and see how the trans was doing. Figure you have about 1,000KM on it now? Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 25, 2017 Author Share Posted May 25, 2017 I wanted to check in and see how the trans was doing. Figure you have about 1,000KM on it now? Probably more than that. Took it wheeling a couple more times too. It's still happy. Link to comment Share on other sites More sharing options...
1987Comanche Posted May 26, 2017 Share Posted May 26, 2017 That's great :thumbsup: . I'll have to R&R the clutch, flywheel, etc when I can find the time to do so. Link to comment Share on other sites More sharing options...
