any one install an alarm system??
Ok I'm about 90% done installing my alarm system on my 87 mj but I've hit one little snag.. I can't figure out where to jump my white wire to for my light flash function. Its the last thing I need. The instructions say it should jump to the parking light circuit but ill be honest I have no clue where that that would be and the 88 electrical manual hadn't been much help. The alarm can send out a (+)12v or a (-) 200mA signal
Any help would be much appreciated
88 Comanche Electrical Manual pg 69.
so if I'm understanding this right, i jump to the dark blue wire or what ever wire is hooked to the R pin on the back of my head light switch and in theory everything even my license plate lights with flash??  I'm basing this off of pg 69, and the switch diagram on pg 97
Yea, your understanding this right. Also, C157 is another location to find this wire. Don't know anything about the 10 pin connector.
Color code: DK BLUE
C269_R (Headlamp)
C157_B (IP to CAB)
Pg 69
Location
C157 (6 pin)
Pg 77
Views
C157
Pg 91 & 92
Color code: DK BLUE
C269_R (Headlamp)
C157_B (IP to CAB)
Pg 69
Location
C157 (6 pin)
Pg 77
Views
C157
Pg 91 & 92
cool, so it dosnt matter what location i pick. the R pin on the head light switch or the B pin on C157 should both work? and is it the same DK Blue wire in both spots? also i was thinking of using a tap spline. it should be fine but i noticed on some f these older wires they don't always give a good connection
