MeanLemons Posted February 27, 2017 Posted February 27, 2017 So when I pulled the engine out of my 91 MJ, I checked the date stamp and the casting numbers. Both says it's a 96 4.0.... I'm putting in a 1994 ax15 behind it before stuffing the powertrain into my 88 MJ. I know I need to get the 1988 flywheel for it. But I'm curious about the pilot bearing. Where does it go into? In the crankshaft of 96 motor Or into the flywheel? I can imagine that it being a 1988 flywheel and if the bushing goes in it, then I would need a CJ v8 bushing. Otherwise I ll need the different one if I'm putting it in the 96 crankshaft?
Eagle Posted February 27, 2017 Posted February 27, 2017 The pilot bushing or bearing fits the crankshaft.
FrankTheDog Posted February 27, 2017 Posted February 27, 2017 94 and 96 used the same size pilot bearing.
