Any pointers to a 3.4 engine swap
You have an empty engine bay? No 2.8 to take parts from?
I've read up for years on the swap but never done it, plenty of write up on it. Usually it is swapping all the 2.8 hardware over then finding a properly balanced flex plate or flywheel.
You can if you get all the wiring for the 3.4 and adapt it to run everything , I've seen that write up a couple of times. Apparently it's relatively simple. not sure what you need to think about timing cover and waterpump wise, I assume you could adapt to use the 3.4 systems whole hog.
Not sure how big a pain the engine mounts will be or the oil pan clearing the axel.
Sent from my iPhone using Tapatalk Pro
There is a kid on here who is almost done doing that very swap PLUS a turbo.
If he doesnt see your thread and comment himself, I will try and get you a link to his build.
Edit:
Here ya go, probably everything you could want to know about a 3.4 swap. Lots of pictures too.
http://comancheclub.com/topic/49436
It's been a while since I checked his progress, sadly the 3.4 went boom in a big way. He tried another one which ran great, but then the transmission went boom. Now he is switching back to original equipment 4.0/ax-15 combo
Has anyone done a 3.4 Camaro Swap. I bought one with a bad Transmission. I have Engine, Harness, ECM... is it hard to do? what parts will i need... never had the 2.8 with it.
Sell 3.4 and buy a 4.0L or LS-based V8 motor is my recommendation. Seems like is as much work as other swaps I have mentioned. Since it sounds like swapping parts from a heep 2.8 is not an option.
