dante2 Posted February 14, 2017 Share Posted February 14, 2017 With the coolant temp sender being a single wire the threads have to be bare for it to ground correct? Thank you for your help. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted February 15, 2017 Share Posted February 15, 2017 I put teflon tape on mine, which probably isn't needed. The threads will cut through when you screw it in, and will make plenty of contact with the head for conductivity. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 15, 2017 Share Posted February 15, 2017 ^^ This. Always use Teflon tape on sensors with NPT and a single output contact. The threads will cut through the tape for a good ground contact, and you don't need to over-tighten the sensor to prevent fluid leaks. Link to comment Share on other sites More sharing options...
dante2 Posted February 15, 2017 Author Share Posted February 15, 2017 Appreciate the responses, thanks guys. Link to comment Share on other sites More sharing options...
