Lower Door to Rocker Seal 55134856 or 55235410AB
Minuit
I need the seals that go across the lower seam of the door and seal against the rocker panel. These go by a few names - "door to rocker seal" or "lower door seal" are the most common. These are usually found on the fancier trim levels. These are also found on 97+ XJs with p/n 55235410AB and are not side specific. Used seals are acceptable, but the rubber part needs to be pliable. Some attach to the door using rivets and others use double sided tape, either is fine.
Pic not mine.
I have a spare set but have to keep them. Lemme see if I can find some..........
EDIT:  There's some on Ebay.
I saw a few on ebay, but they were either stupidly overpriced or the seller had very low feedback and very long shipping time.
I'm just curious as to why you need/want them? I've never seen them before but from looking at it I would think it's gonna trap water and debris in the door jamb.
Because I want them. If installed properly there's no danger of trapping junk. From the XJs I've seen they help with rust in the lower door seam too.
