Question on parts for doing SOA
I'm thinking of doing the SOA instead of 3.5 to 4" lift
If I go the SOA am I missing any parts on this list. Front 30 and rear 35
Rear ---- U-bolts, shocks, extended brake line, bracket for shocks and u-bolts
Front--- Springs, shocks, adjustable LCA and Trackbar, extended brake lines
Not sure on UCA and dropped pitman arm if I need them
And I will check the front end for parts worn out and replace
I used 5.5" front springs and used fixed bent LCAs and adjustable UCAs. Worked out well for setting pinion angle and to center wheels in the wheel wells. You might want to add spring perches to your rear parts list. Get the extended ones that help control spring wrap.
X2 for the leaf centering pins.
Got my ubolts and antiwrap pearches from ruffstuff. Shock mounts from iron rock offroad. Brake line extensions from rockauto (H38620 & H38363). Control arms from rough country. Bilstein shocks and RE coils. Didnt have to mess with a drop pitman arm
