belt routing... wait what?
today i was doing some work on the open cooling conversion for the Comanche and while at it i noticed this
https://postimg.org/image/989x10cb3/
some PO was messing with the engine, isn`t the fan supposed to turn in the same direction as the waterpump?
after a few tries i couldn`t get that belt to fit the right way, at least not without reversing the alternator and/or waterpump, since it has no AC or idler pulley...
the way i see it, i could unbolt the fan/cltuch assembly and turn the fan backwards to correct the airflow and get a new belt with the right lenght...
what you think?
oh my poor baby, some monkey was working on her...
You can buy the waterpump in the same housing that runs clockwise, or counterclockwise, depending on application.
Sent from my SM-N900W8 using Tapatalk
the waterpump runs the right way, the fan/clutch rotate the other way it should...
btw is the link working? anyway, the waterpump must turn the opposite to the crankshaft, and so must the fan, in my comanche the fan turns the same way as the crankshaft...
like i said, some monkey did that job...
