Broken Rear Shocks
Have an 87 MJ with a Rough Country 6" lift.
Was installed by the PO and just noticed both back shocks have broken right above the lower mount point.
I haven't done any extreme offroading any idea why they both would have broken in the exact same spot??
Looks like everything was part of a kit, just got me thinking they were the wrong size or something.
Before I just replace them with the same thing...
Thanks,Dave...
Does the lift use the factory spring plates with the single-shear shock mounts on them? Always seemed a little bizarre to me, that single-shear. It looks beefy enough, but over the years the fatigue from cycling will slowly wear them down and crack them. One of mine is cracked as well.
Check the length of your shocks fully extended, and compare it with the distance from the upper and lower shock mounts The shocks may not be long enough for the amount of suspension lift/flex required. If so one decent offroad trip will tear the eyelet right off the shock body. I did that in Moab in my XJ. It kind of looks like that axle is an XJ axle, or has XJ-style shock mounts on it.
Edited to add: improper size/lack of bumpstops can also contribute to this type of failure.
