Truckcom Posted December 15, 2016 Share Posted December 15, 2016 88 4L BA10, Anyone know of a creative way to get a bit of lube in there to buy a bit of time? Put a new Throw out and slave in a while back and didn't even check the pilot, now it's periodically screaming at me for my negligence. Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2016 Share Posted December 17, 2016 well, if it's any consolation to you, when I pulled my blown peugeot for an AX-15 swap I found my pilot bearing had long since disintegrated. there was nothing left of it but the outer shell. :( still worked to the bitter end. :D (and was surprisingly quiet the whole time) Link to comment Share on other sites More sharing options...
yxmj Posted December 17, 2016 Share Posted December 17, 2016 well, if it's any consolation to you, when I pulled my blown peugeot for an AX-15 swap I found my pilot bearing had long since disintegrated. there was nothing left of it but the outer shell. :( still worked to the bitter end. :D (and was surprisingly quiet the whole time) :thumbsup: Ha Ha Ha :thumbsup: ......it could not squeal because of its absence...... For the OP.....short answer NO......You can add grease to the NEW one when you put it in....... Link to comment Share on other sites More sharing options...
