Automan2164 Posted December 14, 2016 Share Posted December 14, 2016 Hey all, been awhile since I've mentioned I am nipping away at my '87 in the garage, but I am. I really got myself into a corner though... When I took the D44 in the rear apart to send it out I tossed all the drum shoes and hardware in anticipation of all the new parts. This thinking is well and all, except for a year later when I go to put it all back together and realize that I tossed both parking brake bars, and both parking brake levers. In case you don't know what I am referencing, here is a diagram: This is generic, but the parts I need are #19 and 9, as well as the spring on 9. That brings me here. No one has these in stock for a D44, but the D35/8.25 parts in the yard are plenty... Would any of you know if the parking brake levers and bar are the same between the D44 and the D35/8.25? If so, I think I can continue my head of steam. Thanks,Rob Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 14, 2016 Share Posted December 14, 2016 Pretty sure I have everything you need from a d35 if they are infact the same ... Link to comment Share on other sites More sharing options...
Automan2164 Posted December 14, 2016 Author Share Posted December 14, 2016 That would be awesome if they did. The '87 parts book calls for different numbers, but that might just be a left over from the take over. One is in AMC numbers, and one is in Mopar numbers. I don't trust the internet enough to tell me they interchange. Rob Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 14, 2016 Share Posted December 14, 2016 I was under the impression that the drum brake kits used on 35's and 44's were the same so long as the drum diameter was the same. I know some 35's came with 10" drums instead of the 9" ones, same with the 44's. I may be wrong, but that's what I have read and come to understand to be the case. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 14, 2016 Share Posted December 14, 2016 Might be a good time to switch to rear disks? I threw all that stuff away when I converted to disks on both the 35 then the 44. All I saved were the backing plates. Link to comment Share on other sites More sharing options...
Automan2164 Posted December 14, 2016 Author Share Posted December 14, 2016 That was a consideration Don, but I have all the brand new parts for drums. I'd rather just keep it original for the sake of not reordering a pile o' parts. Rob Link to comment Share on other sites More sharing options...
