Crash Posted November 12, 2016 Posted November 12, 2016 For those that run manual trans, 4wd, exploder 8.8 with flange in a longbed.. What is your rear DS length? My MJ is currently 2wd, with 4wd swap in the works. Plan is to run Ax15 + 242 tcase. It already has the F8.8
DirtyComanche Posted November 12, 2016 Posted November 12, 2016 You'll need to know lift height too... I'd really recommend putting the parts in place and measuring it.
Eagle Posted November 12, 2016 Posted November 12, 2016 I'd really recommend putting the parts in place and measuring it. ^^^^ What he said.
Crash Posted November 16, 2016 Author Posted November 16, 2016 I found the 'factory drive shaft length' thread. So, if no one that has swapped in a F8.8 with the stock flange I'll figure it out myself.
