Master7122 Posted November 9, 2016 Share Posted November 9, 2016 I'm going to go look at a 1987 Comanche and the owner says that when you put the gear selector in reverse it moves forward as of it was in drive. Anyone got a clue what that could be? Its Aw4 and 4x4 Link to comment Share on other sites More sharing options...
omega_rugal Posted November 9, 2016 Share Posted November 9, 2016 internal problem with the AW4, either a clutch pack or band... Link to comment Share on other sites More sharing options...
Master7122 Posted November 9, 2016 Author Share Posted November 9, 2016 internal problem with the AW4, either a clutch pack or band... Alright good to know, thank you! Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 10, 2016 Share Posted November 10, 2016 Might just be (and probably is) just a maladjusted shift cable. Crawl under and take a look. http://www.lunghd.com/Tech_Articles/Transmission_and_Transfer_Case/Transmission_Automatic_Shifter_Adjustments.htm Link to comment Share on other sites More sharing options...
