Install Lund visor
To the guys that have one install what kind of screws did you use and what size? Did you put anything to prevent water getting into the hole? I just picked one up and want to make sure I do this right as I will be puttin holes into the sheet metal.
I used the same screws and washers used for the installation of metal roofs on houses, with an additional neoprene washer under the visor between the visor and cab roof. 3/8" x 3/4"L. Sealed top and bottom and they don't leak and never will. Like these but 3/4" long.
