Seat Pan Drivers Broke
My 1992 Eliminator bottom of Drivers seat has a cracked broken metal pan that is located below the foam. Will a 4 door Cherokee pan and/or a 2 door Cherokee both fit OK up to years 1996 or so?  The numbers on the bottom of my pan are  8F C35 (  ) 1371   and 65418 PAN, and 30889. Any one have that pan they could sell me also? Thanks from Alabama.
You can replace your seat bottom with one from any right or left MJ/XJ bucket seat up to and including the 1994 models. They are all the same, and you reuse your existing upholstery cover on the replacement. It's best to get a passenger side seat bottom from the yard as they are always in better shape. I replaced my drivers side with a NOS unit a few years ago. You can still get them but they are quite expensive.
http://www.ebay.com/itm/NOS-OEM-CHRYSLER-PAD-PAN-FRT-SEAT-CUSH-55195850-/322203028663?hash=item4b04cc0cb7:g:1rYAAOSwIgNXlHJs&vxp=mtr
Image Not Found
Image Not Found
Don, thanks again, got a 1994 Cherokee 4 door passenger seat today from pick- n - pull  yard today for $25, took the seat apart and put the bottom pan and foam on my 1992 Eliminator using my original seat bottom fabric that is still in great shape, the pan fit like a glove and was a pretty easy job swapping them, now I finally sit straight and not crooked, glad I did it. Thanks for your great advice and help.
Bill
  • 1 month later...
I just did the same thing.  Got one out of 90-94 Cherokee 4 door on the passenger side and replaced the drivers side in the Eliminator.  It works great.  The only problem I have now is that I have to get used to sitting a few inches higher, lol.  And it only cost $20. Thanks for posting this.
  • 1 year later...
Reviving old thread. So my driver seat also had that gangsta lean to it and I assumed being 30yrs old the foam had just caved in. Took it back to the upholstery shop I recently had redo the interior and come to find out, yup, the seat pan had a hairline crack on the outer side that supports the door side bolster. They said my foam was actually in really good shape but after welding up the seat pan they put a piece of dense foam underneath the bolster to help resist compression for good measure. Like comanche2 said, I now sit substantially higher (normal).......what a difference. $45 to pull the seat, take it apart, weld it up, put it back together and reinstall it. Hell yeah!
Lesson learned? If your MJ has severe bottom seat cushion droop, it may be a cracked pan and not necessarily worn out foam. :beerbang:
