Newton Posted September 22, 2016 Author Share Posted September 22, 2016 Have you tried removing the rear bleed screws and making sure their passages are open and clear? I've had them clog up completely with junk so no fluid could pass by just cracking them open. I have tried removing the bleeder screws and even the disconnected the brake line itself from the caliper to see if it will gravity bleed itself but still nothing Link to comment Share on other sites More sharing options...
88whitemanche Posted September 22, 2016 Share Posted September 22, 2016 Have you tried removing the rear bleed screws and making sure their passages are open and clear? I've had them clog up completely with junk so no fluid could pass by just cracking them open. I have tried removing the bleeder screws and even the disconnected the brake line itself from the caliper to see if it will gravity bleed itself but still nothing Did you try from the prop valve itself? might be clogged... Link to comment Share on other sites More sharing options...
Eagle Posted September 22, 2016 Share Posted September 22, 2016 pen.I have tried removing the bleeder screws and even the disconnected the brake line itself from the caliper to see if it will gravity bleed itself but still nothing Did you try from the prop valve itself? might be clogged... Good point. If you look at the cut-away of the XJ proportioning valve in my photo, there's a plunger inside with a spring around it and a rubber washer or cup on the end inside the body of the valve. Some XJ guys remove that cup because it has a tendency to get clogged and causes the rear brakes to stop working. You should not remove it if used in an MJ, because removing it defeats the proportioning function, but cleaning it and ensuring that the plunger moves freely might help. However, I believe Newton posted that he's using an XJ valve body with ZJ internals. I'm not sure what tat means, but it seems to imply that the thing has been opened up and that the plunger should be clean. Link to comment Share on other sites More sharing options...
Newton Posted September 22, 2016 Author Share Posted September 22, 2016 pen.I have tried removing the bleeder screws and even the disconnected the brake line itself from the caliper to see if it will gravity bleed itself but still nothing Did you try from the prop valve itself? might be clogged... Good point. If you look at the cut-away of the XJ proportioning valve in my photo, there's a plunger inside with a spring around it and a rubber washer or cup on the end inside the body of the valve. Some XJ guys remove that cup because it has a tendency to get clogged and causes the rear brakes to stop working. You should not remove it if used in an MJ, because removing it defeats the proportioning function, but cleaning it and ensuring that the plunger moves freely might help. However, I believe Newton posted that he's using an XJ valve body with ZJ internals. I'm not sure what tat means, but it seems to imply that the thing has been opened up and that the plunger should be clean. correct eagle the spring and stem inside has been replaced with zj ones for correct fluid pressure for the disk brake and don't think its clogged i have fluid going to the front just not the rear might be a clogged line trying to narrow it down Link to comment Share on other sites More sharing options...
Eagle Posted September 22, 2016 Share Posted September 22, 2016 Good point. If you look at the cut-away of the XJ proportioning valve in my photo, there's a plunger inside with a spring around it and a rubber washer or cup on correct eagle the spring and stem inside has been replaced with zj ones for correct fluid pressure for the disk brake and don't think its clogged i have fluid going to the front just not the rear might be a clogged line trying to narrow it down Look again at that photo of the cross-sectioned XJ proportioning valve. The front circuit is completely independent of the rear. The fact that you have fluid to the front doesn't tell you anything. Did you replace the rear flex hose, or is it the original 25+ year old hose? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 23, 2016 Share Posted September 23, 2016 Have you tried removing the rear bleed screws and making sure their passages are open and clear? I've had them clog up completely with junk so no fluid could pass by just cracking them open.I have tried removing the bleeder screws and even the disconnected the brake line itself from the caliper to see if it will gravity bleed itself but still nothing I also have disk brakes in the rear also and my rear calipers wouldn't gravity bleed either. But when I removed the bleed screw from the RR caliper and pushed the brake pedal, brake fluid shot out. After I did that then reconnected I was able to bleed them normally with wifey pushing the pedal. Try it to make sure your brake lines going aft are not restricted. Link to comment Share on other sites More sharing options...
Newton Posted September 23, 2016 Author Share Posted September 23, 2016 Good point. If you look at the cut-away of the XJ proportioning valve in my photo, there's a plunger inside with a spring around it and a rubber washer or cup on correct eagle the spring and stem inside has been replaced with zj ones for correct fluid pressure for the disk brake and don't think its clogged i have fluid going to the front just not the rear might be a clogged line trying to narrow it down Look again at that photo of the cross-sectioned XJ proportioning valve. The front circuit is completely independent of the rear. The fact that you have fluid to the front doesn't tell you anything. Did you replace the rear flex hose, or is it the original 25+ year old hose? You were right eagle it is the rear flex hose...its clogged Link to comment Share on other sites More sharing options...
Eagle Posted September 23, 2016 Share Posted September 23, 2016 You were right eagle it is the rear flex hose...its clogged Even a blind squirrel finds an acorn once in awhile. :) Glad you finally found the problem. Things like that can drive you nuts. Link to comment Share on other sites More sharing options...
Newton Posted September 23, 2016 Author Share Posted September 23, 2016 You were right eagle it is the rear flex hose...its clogged Even a blind squirrel finds an acorn once in awhile. :) Glad you finally found the problem. Things like that can drive you nuts. yup was starting to drive me nuts ...thanks for ur help youre far from a blind squirrel Link to comment Share on other sites More sharing options...
