Knucklehead97 Posted September 10, 2016 Share Posted September 10, 2016 When I install the front axle I'm building I want to try and level out my trucks suspension. Last time I checked a 1.5" spacer would get it about right, probably a little less. But I already have two sets of 1.75" spacers that I got for a good deal and would prefer not to buy more pucks. Could I remove the rubber insulator (it's 5/8"'s right?) And run the pucks without it? That would get it JUST about where I want it, I think, I just don't know if it's safe. Searching has brought up mixed opinions of course. I trust you guy's opinions way more than random people in my search bar. Link to comment Share on other sites More sharing options...
Eagle Posted September 10, 2016 Share Posted September 10, 2016 Yes, you can swap the spacers for the isolators. But how is that going to solve your problem? You said 1.5" spacers will be a little sort of where you want to be. Why wouldn't 1.75" spacers be right where you want to be? If you take 1.75" and subtract 5/8 (.625) you're going to get 1.125" (1-1/8). Isn't that going in the wrong direction for what you're trying to accomplish? Link to comment Share on other sites More sharing options...
Knucklehead97 Posted September 10, 2016 Author Share Posted September 10, 2016 I think that adding 1.75" spacers would make the front look higher than the rear, which is why I was going to try out running without the isolators. I need to do the measurements again but last time I checked I believe it ended with just under 1.5" raising it to where I liked it. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted September 10, 2016 Author Share Posted September 10, 2016 Maybe 1.75" will be close enough to what I want. I just fear it beung higher in the front and looking terrible. Link to comment Share on other sites More sharing options...
FrankTheDog Posted September 14, 2016 Share Posted September 14, 2016 I have run with and without isolaters with spacers and could never tell the difference. I have also stacked isolaters to adjust it incrementally. Link to comment Share on other sites More sharing options...
1989 comanche mj Posted September 20, 2016 Share Posted September 20, 2016 You don't need the isolators, I don't like them cause they squich over time. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted September 20, 2016 Author Share Posted September 20, 2016 I measured it all and without the isolators it should level out correctly. Glad that it's safe to run wjthout them! Link to comment Share on other sites More sharing options...
