Jackrabbit41 Posted September 7, 2016 Share Posted September 7, 2016 Should I get a new flywheel or use the one I have? Mines falling out so it could be damaged. I don't have the time to get it re surfaced. Thanks Link to comment Share on other sites More sharing options...
gogmorgo Posted September 7, 2016 Share Posted September 7, 2016 Why do you say it's falling out? Two possible causes, either backed out bolts or its cracked. Either way it's probably best to have a new one on-hand during the swap so you don't have to run around and find one half-way through. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted September 7, 2016 Author Share Posted September 7, 2016 Why do you say it's falling out? Two possible causes, either backed out bolts or its cracked. Either way it's probably best to have a new one on-hand during the swap so you don't have to run around and find one half-way through. Falling out as in lose bolts I think Link to comment Share on other sites More sharing options...
Eagle Posted September 7, 2016 Share Posted September 7, 2016 The factory service manual says NOT to resurface the flywheel. If it's not badly hot-spotted, I;d use it again. Link to comment Share on other sites More sharing options...
