chris71 Posted August 2, 2016 Share Posted August 2, 2016 hey all been a few months since i've been on here , have a couple questions . 1. does anyone have any experience with c2c fab's floorboards , if so were they a good fit ? 2. needing to remove the old airbox since i'm running a spectra cold air intake , i left the old air box due to the vac lines and have been unsure if i can just remove them and plug the vac ? anyhow i've been making good progress on the conversion from 2wd to 4wd , about to start the install of the 8.8 this weekend , and bushwacker fender flares , gotta do the floorboards soon there getting bad , also does anyone remember what that frame treatment is starts with a p black in color it's a undercoating ? hope those pics post if not i'll try again , this is where i'm at in the work being done dana 30 is in new suspension and lift , ax15 and np231 are in driveshafts are being shortened . getting close thanks in advance for any help with the above questions . Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 2, 2016 Share Posted August 2, 2016 The vacuum lines on the airbox air for the intake heater valve junk. You can delete all of it, as it won't be doing anything with a CAI. Be sure to cap/plug it at the manifold. No comment on the floorboards. Link to comment Share on other sites More sharing options...
chris71 Posted August 2, 2016 Author Share Posted August 2, 2016 cool thats what i was thinking , just wasn't 100% sure thanks :thumbsup: Link to comment Share on other sites More sharing options...
Big Dan Posted August 2, 2016 Share Posted August 2, 2016 I installed the C2C floorboard pans in mine. I was generally pleased. It did take some beating, in some areas, to fit correctly. I also purchsed the pans in two sections per side (front left, back left, front right, back right) to assist in the fitment issue. Link to comment Share on other sites More sharing options...
chris71 Posted August 2, 2016 Author Share Posted August 2, 2016 good to know there a good fit , i didn't see them in two sections just left and right sides , i'll look again if not i can cut them . only really need the front half of each one . the back halfs look good with only small pin holes one or two spots . Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 2, 2016 Share Posted August 2, 2016 ....also does anyone remember what that frame treatment is starts with a p black in color it's a undercoating ? POR-15 Link to comment Share on other sites More sharing options...
chris71 Posted August 3, 2016 Author Share Posted August 3, 2016 thank you hornbrod :thumbsup: Link to comment Share on other sites More sharing options...
