SBpunk Posted August 2, 2016 Share Posted August 2, 2016 1992 MJ LWB original D35In the process of swapping in an 8.25 and was wondering what everyone did for the rear load sensing valve on the brakes? I tried to find the delete write up but no luck and the few I found none of the pictures were loading. I'm not even 100% mine works but rather be safe than sorry when transporting the little one. Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 2, 2016 Share Posted August 2, 2016 To retain the load sensing prop valve you would need to fab a new mounting bracket or mod the existing for the 8.25 cover bolts and an adjustable rod to get the correct rear brake bias. When I junked the D35 and swapped in a D44 I had to change the mounting bracket. Thanks G. :thumbsup: But first I'd verify the valve is working by tie-wrapping the arm in various positions and testing it on a wet parking lot to see how it affects the rear brakes. If it does nothing, I'd eliminate it. Link to comment Share on other sites More sharing options...
88whitemanche Posted August 2, 2016 Share Posted August 2, 2016 What I did was plug the front bottom portion of the distribution block and ran that line all to way to the back where it connects to the rubber brake line which I had to change the fitting to make it work.... Link to comment Share on other sites More sharing options...
