TorqueFlight999
FireManDango
Looking for TorqueFlight 999. I have a AW4 to trade if interested. Located in south Florida. Thanks!
What engine do you plan to mate it to? I searched from Jupiter to Miami and couldnt find one for under 800. I found one for a Wrangler with 4.0L but it was all the way in Apopka Fl for 550.
Sent from my SM-J700P using Tapatalk
The engine I'm mating it to is out of a 97 Cherokee. Did you find it on Craigslist? I may have to take a trip up there. It's about a 3 hour drive though :/
I don't use CL. I called every salvage yard and transmission shop i could.
Just an FYI...
The TF999 was NON fuel injection (NO CPS so you would need a relocate kit if using on Fuel injected 4.0L) and its without a lock up converter
The 32RH is the modern version of the TF999 for fuel injection (has CPS mount) and has a lockup converter...
Try Car-part.com to find a 32RH which was 91-03 As I think they switched in 04 to the 42RLE (basically 32Rh with an electronic 4th gear)
Well.... I actually have a rebuildable unit in my storage room.  My plan was to use it for my CJ5.  Have now had foot surgery on both feet and think I can actually do fine with my now-planned hydraulic clutch.  Not sure if you are only looking local but thought I would throw it out there.
