bhawkin2 Posted February 21, 2006 Share Posted February 21, 2006 I just got this truck friday the 17th. My front marker lights stay on all the time as well as the left turn signal indicator on the dash. I was thinkin it might be a bad ground somewhere but I wasn't sure. Thought I'd see if any of you guys have run across this problem? By the way it's a 86 comanche 2.5L auto 4x4 If it helps. Thanks Link to comment Share on other sites More sharing options...
GirsMJ86 Posted February 21, 2006 Share Posted February 21, 2006 sounds like a ground. i had a similar problem with my taillights when i took a custom trailer plug off my 86. i rewired it to the stock wire chart but when i tried it the lights were stayin on and i found out it wasnt grounded right nemore. Link to comment Share on other sites More sharing options...
jaekl Posted February 21, 2006 Share Posted February 21, 2006 Bad ground. Same problem on my 86 Cherokee. My problem was right at the light socket. Power crosses thru the double filament lights and then feeds back up to the turn signal ground in the dash. Fixed mine by flowing solder over the rusting areas. Long term fix of course is to replace. Link to comment Share on other sites More sharing options...
bhawkin2 Posted February 21, 2006 Author Share Posted February 21, 2006 Thanks I'll have to check at the sockets,someone actually broke the lenses to take the bulbs out so it wouldn't drain the battery. I got 2 new lenses on the way. Thanks for the help i'll let you guys know where the issue was. Link to comment Share on other sites More sharing options...
pingpong Posted February 23, 2006 Share Posted February 23, 2006 burnt out light bulb could cause that problem, as well as a burnt out flasher relay. Patrick Link to comment Share on other sites More sharing options...
