Sevik Posted May 25, 2016 Posted May 25, 2016 Is there any way to save the steering column shifter when swapping an interior, including the steering column itself into MJ? IF I leave the stock steering column, will a new steering wheel fit on it? I really like those and could use the space for OX lockers manual shifter on the floor. Gear position indicator is not the problem, there are aftermarket solutions available.
HOrnbrod Posted May 26, 2016 Posted May 26, 2016 What do you mean by "a new steering wheel"? A 96 and up airbag wheel?
Sevik Posted May 26, 2016 Author Posted May 26, 2016 What do you mean by "a new steering wheel"? A 96 and up airbag wheel? yeah, with cruise control also
relyt120 Posted May 27, 2016 Posted May 27, 2016 I've seen a 95 or 96 with a column shifter before, never a 97+ though
HOrnbrod Posted May 27, 2016 Posted May 27, 2016 ^^ Yes, 96 was the last year for XJ column shift vehicles.
ggcnash Posted June 1, 2016 Posted June 1, 2016 I've often entertained the idea the obvious swap would be out of a late 90's Dakota almost exact column with column shift. Sent from my SAMSUNG-SM-G890A using Tapatalk
