Yes I am new here. Partially, I own a 1986 2.5 Comanche custom 5 speed 4x4. All stock.
What are my options best or worst to upgrade the 2.5 to a larger engine.
Reason is I recycled wood shipping containers and make furniture. And I tow a trailer to craft sales. I'm assuming that a larger engine will make a little more fuel economy than the 4 cylinder.
Thank you.
Oh, my name jM68, is 86Mj reversed.
You can either look into a 3.4L V6 swap. will have to find a 2.8 v6 from a comanche though. Those are more popular for the 86 comanche's. 4.0L can be done on 86's but it's really time consuming. I would sell the 86 and by a 4.0L comanche.
Many 86 MJ owners swap Chevy 3.4.  I've read it is larger version of the V6 than the 2.8 that came in the 86s.  This way you can gain 2 cylinders.  The issues with a 4.0 swap is the firewall on the 86 may need to be "modified" to fit the longer engine block.  There are lots of write ups on the swap on Comancheclub.
Realistically, how much more power do you need? I've pulled a 3500lb trailer with my SWB 87 equipped with 3.55's, an AX4, a 2.5, and 31's. Getting it going has not been an issue for my truck. I do plan on going to 4.56's and an AX5 in the future on mine. Perhaps you can get away with a gear swap too.
