Transmission will only hold in park occasionally.
column shift
Then only the top procedure on the link I provided applies. Unlike the floor shift, the column shift has only one cable that does the gear shifting and PARK interlock. Before trying to adjust the cable and possibly breaking the 20+ year old plastic pieces, pull the shift cable off the trans lever by removing the two bracket screws. Then put the gear selector in PARK (make sure the detent clicks in), then bolt the bracket back on and eyeball how close the cable end hole is to the lever stud. This will tell you how much (if any) adjustment is needed.
A broken parking pawl detent spring can also cause the tranny intermittent PARK engagement.........
column shift
okay I'll give that a shot.
if the pawl is broken, how difficult is that to remedy
