rammstein Posted May 3, 2016 Posted May 3, 2016 Ok I don't know if I am posting in the right area but here is the history. 88 Comanche Pioneer short bed, all stock. 150 AMC married to an AX5. Dana 35 rear end 2WD. Interior/exterior in good condition. Clean under the hood and under-body, no rust. Sat in the woods for 10 years. New brakes, hoses, belt, air filter, exhaust. Changed oil right off the bat; idled at least 50 miles during initial diagnostics while running marvel in oil, fuel and a few drops in cylinders. Then filled fuel tank, changed oil twice and new filter. Engine sounds great except uneven idle. No oil on driveway ... Horrible death wobble at 45, yet to rule out tires. New concentric bearing on ax5. Not the right hub/ knuckle on 2wd front end, rotor on that side shot, the inside brake pad had to be cut to fit and the new rotor was not a match. Rotated drive shaft 180 and new u-joints to no effect. So either tires and or bushings. Overheating; pump is OK so thermostat next. Also no external or internal leaks of oil or coolant. Also big issue with oil sumping into air filter but baffle in v-cover is OK. Think air leakage is causing a bumping effect due to rotten grommet. Update: New thermostat; still overheats without boil over, I know the oil is getting too hot because lifters start to flatten and get mechanical noise, using 10w-30, in process of checking oil pressure... Looking for a breather/oil separator that will fit to replace the direct air filter hose connector but cannot seem to find one. Thanks and keep truckin!
jdog Posted June 28, 2020 Posted June 28, 2020 BODY: TM61 *X4 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE AGJ Driver Assistance Group APA Monotone Paint BCQ 750 Amp Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area CLE Front Rear Floor Mats DDJ DESCRIPTION NOT AVAILABLE EPD DESCRIPTION NOT AVAILABLE GAC Tinted Glass Windows GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Front Bumper NAA Federal Emissions NMB Standard Duty Engine Cooling PS4 Bright Platinum Metallic Clear Coat QS4 Bright Platinum Clear Coat RAB AM/FM Radio SBA Power Steering SCE Wrapped Steering Wheel TBG Compact Spare Tire WJD 15X7.0 Styled Steel Wheels 3LX DESCRIPTION NOT AVAILABLE
