KCsurfer420 Posted April 10, 2016 Share Posted April 10, 2016 SPECS: BODY: 87 jeep Comanche short bed. Was originally a 2.4L 2wd base truck. Body recived fire wall mods to install newer dash, hvac box and wiring harness, door pins were modded to acepted 99 doors. Bed has been lined with raptor upol liner and body was repainted desert tan, not a show paint job but it looks nice. AXLES: dana 30, 3.55 gears with a spartan locker, lca skid plates, Terra flex high steer ($$$$), and a double sheer Rubicon express track bar. Rubicon express lower arms and adjustable rough country upper arms, also has rough country sway bar disconnects. Cryco 8.25 rear axle, 29 spline shafts and a spartan locker set up for a SOA in a Comanche. MOTOR: 4.0l out of a 99 xj, was rebuilt at time of instalation, .30 over. Has bored out tb, high volume melling oil pump, brown dog block brackets ($$$) iron man HD motor mounts, eddlebrock dual outlet header ($$$) and 99 high flow intake manifold. TRANS AND TRANSFER CASE: ax15 out of a 99 xj has new clutch and red line mt30 oil shifts like it should Np231 transfer case, has Chevy HD wide chain and gears and a 6 pinion planetary. Works as it should. LIFT: 6.5" IRO lift coils in front, adjustable upper rough country arms and lower rubicon express arms, rough country sway bar disconects, Rubicon express double sheer track bar, spring over axle in the rear, BDS 6" shocks at all 4 corners. INTERIOR: all of the interior came out of a 99 limited Comanche. The color is dark grey (aggate) has all the wood trim that the limiteds come with. Has ultra rare HEATED, power leather seats ( heated leather seats only came in 2000 and 2001 cherokees) also has the proper 2 door windows switch for the conversion installed in the drivers door. Ac and heater work as they should and has a nice jensen cd/ radio installed. The Guage cluster shows 144674 miles on it but there is less than 20000 miles on motor. EXTERIOR: Front bumper is from loans metal products and has a warn winch installed on it that works as it should, also has 4 led pod lights 2 on the bumper and 2 on the b pillars. Rear HD bumper with 2" hitch reviver. Truck also has windows visors installed. Also has bushwacker flat fenders installed. WORK NEEDED: As with any ting else this truck does need a small amount of atention. Curently it is getting deth wobble between 45 and 50. I have narrows it down to the upper control arm joints. Rough country has the rebuild kits for 25$ a joint. Also needs a head liner inside the truck. You can buy a new one on ebay for roughly 100$ (ebay seller a1500ram) and it curently has a slight oil leak from the pan gasket. Also has a check engine light because the front of sensor is bad. I built this truck over the couse of 2 years and no expense was spared. I want the nicest 99 swapped mj with in 1000 miles of me. I have over 1000 hours in this build. I am selling for a friend that I traded the mj to for his rock buggy. I hate to see it go but it deserves a good home with a loving owner. There are VERY FEW of these swapped mjs because it takes a LOT of work to complete the swap. Would like to get 7500.00 or best offer or will trade for a nice jeep TJ daily driver or a diesel tuck (dodge or ford 7.3 only) 9159209690 call or message me with any questions / offers. Don't waste my time, if you Wana low ball me I'll either ignore you or hang up on you... thanks... Sent from my SM-G900T using Tapatalk Link to comment Share on other sites More sharing options...
DirtyJeepGuy Posted April 12, 2016 Share Posted April 12, 2016 Beautiful! I will vouch for that swap. It takes a ton of time to get it complete. I had mine 85% done when I was forced to sell (landlord). Link to comment Share on other sites More sharing options...
benjy_26 Posted May 5, 2016 Share Posted May 5, 2016 I'm amazed someone hasn't picked it up yet. Link to comment Share on other sites More sharing options...
MidTenManche Posted July 22, 2016 Share Posted July 22, 2016 PM sent Link to comment Share on other sites More sharing options...
Trapn6.0 Posted November 4, 2016 Share Posted November 4, 2016 This still available? Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
KCsurfer420 Posted May 31, 2017 Author Share Posted May 31, 2017 Ive got another one that I'm almost finished with if any one is interested in it. PM me for more info Link to comment Share on other sites More sharing options...
Archived
