OEM and Rust Free - Rocker Panels and Cab Corners
500 MJ
Here we go, starting to look at my options here. I know that the rockers are supposedly available from the aftermarket,but the quality and the fit of aftermarket stuff does not impress me. I am looking for an OEM set for both sides that has been cut off of a truck, or if I am lucky enough an NOS set.
My other option is to have a new set of rockers broken out at a local fab shop or try and make my own. The cab corners I have can be made to work, but I'd rather start with something else. My cab corners are just starting to rust, but they have been repaired before. The passenger side has holes from a dent puller, thanks to a previous owner.
This will be for my white '90...
Thanks,
New cab corners and rockers are not available anywhere, not OEM ones anyway.
I did find this recently - http://www.ebay.com/itm/281985048571- basically they are the kind of rocker that slips over the current rocker. I discovered them because the driver side rocker on my 92 is this one I believe. Pretty cheap and if you are OK with "close enough" they actually look good. The curve just below the door is ever so slightly different but I think it would work for a lot of folks.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
