Daily that can go places
I have been looking at this truck for a while since I moved into my new house and had the luxury to look under it and check the vin and found it has all the goodies I was hoping for 4.0, 4x4, D44, AX15 and surprisingly little rust despite it being an 1989, finally decided to get rid of my 2003 TJ and buy this truck a while ago and have been around jeeps for a while now and even had a job building jeeps for 4 years at ranging from the simple lift and tires to engine conversions custom racing suspension and on and on. And now I'm working on building up a new project again and now I know where I want the build to go. After I finally sold my TJ I used started to gather parts together so I can take a whole weekend and put it together so it doesn't have to come apart more than once unless something is broken.
What I have so far
-6.5" Clayton Offroad pro link
-SOA brakets
-8274 Needs rebuild and motor replacement
-35" 12.5" R 15 Goodyear MT-R
-15" Custom modified wheels
-Inner air lock beadlocks (reason why wheels are modified)
-Redneck Ram hydro assist with ported box
-Napier Precision Products Flares
-4.56:1 yukon gears
-True trac limited slip Dana 44 and Dana 30
-Donor late model Dana 30 (to rid myself of the vacuum disconnect)
What I'm missing
-Unibody stiffeners
-JCR DIY front winch bumper
-JCR DIY rear bumper/build a rear bumper
I'll post some pictures once I can figure out how to get them to post
There's a thread or two pinned in the "testing" forum that'll help you with pictures. I would actually recommend against using photobucket (it's caused me nothing but headaches although many members use it with reasonable success) and there's a couple other recommendations further along in that same thread.
getting it all cleaned up trying to get all the tree sap and moss off of it
getting to work right after I got it running
test fitting for new fender radius and bump stop height
the TJ I finally sold
