Front axle question
From my observations, the CV's are mostly considered weaker because if they break, you have to replace the entire shaft, not just the joint like you might be able to get away with on a u-joint. The boots can also get compromised pretty easily and trap moisture and grime, which will lead to premature failure of the joint.
I've never managed to take out a u-joint without also blowing apart the yoke, and really appreciate the smoothness of the CV's on the road.
I've just got the cheap Sur-track replacement ones that RockAuto listed for my MJ. They've worked great for the last 5000 miles.
