Newton Posted March 18, 2016 Share Posted March 18, 2016 All fuse in fuse box hot even with the key out of the ignition is that normal? Link to comment Share on other sites More sharing options...
88whitemanche Posted March 18, 2016 Share Posted March 18, 2016 No there must be a power wire grounding out somewhere... Link to comment Share on other sites More sharing options...
Newton Posted March 18, 2016 Author Share Posted March 18, 2016 ok ill check it out Link to comment Share on other sites More sharing options...
Marine1Texas Posted March 18, 2016 Share Posted March 18, 2016 it could be in the ignition since that is where most the fuses get power turned on. The other thing is some one wired direct positive wire after a fuse that is resonating back to the fuse panel. I see no way a ground would cause the fuse panel be powered, only ideas come to mind are ignition not shutting off as it should, a wire from battery feeding back, and hard but possible a relay that has shorted out and feeding direct current back in to the fuse panel. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 18, 2016 Share Posted March 18, 2016 Disconnect that black dash ground wire you just hooked to ground in your other post and use your meter to see if you have any voltage on it. Link to comment Share on other sites More sharing options...
