97 swap fuel tank suggestions
You should be able to use the stock MJ tank? Even when swapping engines etc, the only thing that would MAYBE need to be swapped would be the fuel pump in the tank to accommodate different pressures?
97+ front sheet metal has nothing to do with the fuel tank?
If you need to get a new aftermarket tank, Spectra Premium makes them and a number of online stores carry them.
Junk yard pokes holes in all the dakota tanks, would I be better off buying a new one from napa or are there other tanks that would work better
What are you driving? Edit your signature detailing the year, engine, etc. so we don't have to guess.
