Dom U Posted February 17, 2016 Posted February 17, 2016 Just curious if anyone has run 4.10 gears with 30x9.5x15 tires,4.0 engine? How was it on/off road?
Eagle Posted February 17, 2016 Posted February 17, 2016 70 MPH will be 2500 RPM in overdrive. Not bad at all -- that's what the earlier versions of the AMC I-6 were all geared for in the days before we had overdrive transmissions. Should give you a nice crawl ratio off-road.
64 Cheyenne Posted February 17, 2016 Posted February 17, 2016 Just curious if anyone has run 4.10 gears with 30x9.5x15 tires,4.0 engine? How was it on/off road? Decent combo, I run 31 10s 4.10, good all around for dd and some great off road capability. (with a front lunch box)
87Warrior Posted February 17, 2016 Posted February 17, 2016 Just curious if anyone has run 4.10 gears with 30x9.5x15 tires,4.0 engine? How was it on/off road?Great/Great. It is equivalent to what a stock TJ Rubicon came with from the factory. A higher revving 4.0 will also help keep itself lubricated ;)
