ba10/5 / ax15 question
My Ax15 has external slave, we did it when we installed in. however before the swap I had the internal slave on the BA10.
Why not convert to external slave then only if you need to replace clutch you have to pull the tranny! They have many write up for it to be done.
Some directions here
http://comancheclub.com/topic/33806-ax-15-internal-external-slaves/
this is a good write up here
http://www.jeepforum.com/forum/f12/ax-15-internal-external-slave-cylinder-clutch-line-write-up-592098/
thanks Tim
off to the wreckers to complete my external ax15
noriyori_kudo
ive done the ba10/5 to ax15 external slave and 4wd conversion before,
i have a pre bled assy and 3 spare clutches and fly wheels
but my issue is, i gave my external bell housing and release fork to another jeeper before i started on my 7th comanche
i didnt want to spend more money than i needed thats all, external bell housings are hard to come by around these parts,
LOTS of jeepers doing the same thing
(I'm actually making a franken ax15 from 3 transmissions, and a np231 from 3 transfercases, gotta love free parts)
