rdp001 Posted June 25, 2007 Posted June 25, 2007 Ok I have completly wasted rear spring on my 88 MJ,just went on a ride with a couple people in Ocala and there was a CJ with this 1/4/" Eliptical set up running around.I have seen some great articulation out of that CJ and I can get my hands on one reasonable. Does anybody have any experience with that setup on an MJ and if so how did it work out!? I would make a four link with it and built a fuel tank for in the bed. :eek: any info would be great!
DirtyComanche Posted June 26, 2007 Posted June 26, 2007 1/4 elliptical itself really only indicates the spring characterisitics. It's like saying "air shocks" or "coil-overs" and asking how they worked. The reality is that most of how well they work is dependant on other factors. Basically, how you design and build your 4-link is going to matter more than it being 1/4 elliptical suspension. A LOT more. Do your homework and spend the money on the material and joints. 1/4 elliptical does offer advantages in that the springs have both a positive and negative rate. IE, they will fight drooping once they reach a certain point. This helps with stability to a degree. It is also cheap (comparitivly) in that a guy can cut down some F-250 front leaves to make it work. Anyways, I've never run them. But I've seen them.
rdp001 Posted June 26, 2007 Author Posted June 26, 2007 Thanks for the info ,I think I am going to try it ,and will make pictures and post .I have a way to set up a 4 link onto my 44 s so I will get that done firts and then put the springs on . :cheers:
pingpong Posted June 26, 2007 Posted June 26, 2007 I think when done right 1/4 elliptical rocks, but when not done right they suck @$$. It is just like any other properly designed 4 link except instead of using coilovers/airshocks/ captured coils, you are using the springs to hold the weight.
