OK guys so I'm wrapping up my 4x4 swap Just in time for snow... I've encountered an issue. The AX15 and 231 Tcase is out of a YJ that is in my MJ. Number one the front output is different, and number two the front driveshaft I have is the wrong length. (It's from an auto xj) by swapping the output flange will I be OK with the auto driveshaft or will I need another?
What year was the YJ you got the tcase from?  The output shafts changed at some point in Jeep history.
As for the front drive shaft, the lengths are different between a manual and auto trans.  An AW4 is longer than an AX15.  That means a DS from an auto will be too long for your manual.  Sorry.
