teamsmith Posted January 4, 2016 Share Posted January 4, 2016 I'm loosing some coolant from the big thermostat hose and I believe it's due a lack of clearance for the hose due to my using the renix aluminum valve cover on my '98 swapped engine. I was going to put the 98 cover (smooth steel) on to see if it would give me any more room to get the hose clamp in there but I see that I am missing 3 grommets for the cover. My searches tell me that I need pn# 2946079, http://www.quadratec.com/products/51309_0101.htm but the image is just of a rubber grommet and what is on my cover has a metal backing around it. Is it ok to just order these grommets or is there something else I need? I have the year appropriate felpro gasket, I just need the appropriate grommets. Thank you Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 4, 2016 Share Posted January 4, 2016 There should be a metal insert that goes in the grommets. The gasket is different as are the bolts. A new Felpro gasket will come with the rubber grommets. Link to comment Share on other sites More sharing options...
xjrev10 Posted January 5, 2016 Share Posted January 5, 2016 There should be a metal insert that goes in the grommets. The gasket is different as are the bolts. A new Felpro gasket will come with the rubber grommets. Mopar gaskets do NOT come with grommets. Ask me how I know. Felpro it is for all gaskets in the future! Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 5, 2016 Share Posted January 5, 2016 Link to comment Share on other sites More sharing options...
teamsmith Posted January 13, 2016 Author Share Posted January 13, 2016 ok; so I have a felpro blue gasket and the valve cover from the '98 but am missing a couple of grommets. I would like to avoid buying a whole new felpro gasket (which, if I'm understanding the comments, includes the grommets) since I only need 3 grommets. Is that possible? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 13, 2016 Share Posted January 13, 2016 I have an 99 valve cover outside and can see if it has some grommets you can have for the price of shipping . Link to comment Share on other sites More sharing options...
