AeroNautical Posted January 2, 2016 Share Posted January 2, 2016 I've searched for turn signals that didn't work, but all cases I found were solved by a replaced fuse or flasher relay. This isn't the case for me, I've replaced those, as well as the ignition switch on the steering column, and no turn signals. Hazards work just fine. The timing of this is absolutely terrible, the last 2 months I've been trying to get my MJ and a trailer up to where I live now (6 hour drive) but a cracked fuel tank (replaced today) and NOW turn signals don't work prevent me from doing this. I need the signals for the uHaul inspection. Any ideas? Link to comment Share on other sites More sharing options...
sloride Posted January 2, 2016 Share Posted January 2, 2016 Refresh your grounds? Link to comment Share on other sites More sharing options...
AeroNautical Posted January 2, 2016 Author Share Posted January 2, 2016 Ohh yeah, cruisers tips and I are good friends. The problem just arose last week, haven't touched it since. I've been making exclusive trips back to sc to fix the problems that just pop up out of nowhere, this is the latest, and I NEED it fixed by tomorrow. Link to comment Share on other sites More sharing options...
MJDigger-CT Posted January 2, 2016 Share Posted January 2, 2016 Hmm well you said you already replaced the fuses . Gunna throw if it out there , have been wrestling with some electrical issues on my MJ . Blinkers worked sometimes , over looked at first when I was fixing it but it end up being , where the fuse slides in there's the two of the electrical contact plates that kinda sandwich the prong on the fuse in and on the right side of mine. The bottom plate there was sheared off. So it would only work when the fuse rattled on there just right. Don't know the technical terms but I hope that made sense. I ended up just sautering some extra material on that side of the fuse for now until, I can get in there and fix the problem. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted January 2, 2016 Share Posted January 2, 2016 Checked your bulb bases for corrosion within the sockets. That would be the next place I'd start. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 2, 2016 Share Posted January 2, 2016 Checked your bulb bases for corrosion within the sockets. That would the next place I'd start. Yepper. Link to comment Share on other sites More sharing options...
AeroNautical Posted January 2, 2016 Author Share Posted January 2, 2016 I have actually replaced the fronts recently, and the hazards work fine. Would that cause a separate issue with the turn signals? Link to comment Share on other sites More sharing options...
cruiser54 Posted January 2, 2016 Share Posted January 2, 2016 Turn signal switch in the column. Unplug the switch at the base of the column and clean the contacts and plug it back in. It's that long skinny flat one. You replaced both flashers? Link to comment Share on other sites More sharing options...
AeroNautical Posted January 3, 2016 Author Share Posted January 3, 2016 I have, yes sir. I've localized the problem to a ground I can't seem to find. I wiggle the harness and smack it a few times and they work for a short while. Are the gauge and signals on the same ground? Noticed my gauges seem a bit off too. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 3, 2016 Share Posted January 3, 2016 Where are you wiggling the harness? Ever reviewed my Tip 3 and 18? And BTW, this is progress, ain't it? Link to comment Share on other sites More sharing options...
