Heyo
So I've been working on my jeep for a bit now added a 3.5 lift and just over all cleaning everything up. Has been on stock wheels and tires since I've had it. Have been planning on geting a bigger set of tires when I'll be close to registering it. So my sisters boyfriend was scraping a beat up wj and had a set of 255/75r17 with out the wheels laying around with about half the tread left on them . A bit bigger than I was planning for the MJ but they were free so I couldn't say no. So here's the question do you all think I should by a cheap set of 17s and make them work ? I'm pretty sure the fitment will be tight I don't want to have to trim . Ideally I'd like to run a par of 32's with the factory back spacing and such. But any thoughts and comments would be welcome thanks.
That works out to a 32x10-17 (approximately). They might work with a 3/1/2" lift but the wheel backspacing is going to be critical.
Ok ok planning on some thing simple like some black steelies in that area. Stock is 5 1/4 I believe and the issue comes when you move outward and run the risk of getting involved with the flares
