gunparts Posted December 31, 2015 Share Posted December 31, 2015 1987 with a 5 speed manual it is stuck in 1st gear, will any transmission fit or only a 1987? and I plan to pull the truck backwards and see if it will release what do you think? Thanks Link to comment Share on other sites More sharing options...
87MJTIM Posted December 31, 2015 Share Posted December 31, 2015 87 5sp but what engine? 4.0 or 2.5. If 4.0 and a stock trans, you have BA10/5. Most people will say it is not worth fixing. Look for an AX15 from a later model XJ, preferable one with an external slave. If 2.5, then it would have come with an AX5. Beyond that, I don't know. Link to comment Share on other sites More sharing options...
gunparts Posted December 31, 2015 Author Share Posted December 31, 2015 Thanks, and it is a 4.0, Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 31, 2015 Share Posted December 31, 2015 Is the slave releasing, MC full? Link to comment Share on other sites More sharing options...
gunparts Posted December 31, 2015 Author Share Posted December 31, 2015 I do not know how to tell if the slave is releasing or not, the clutch works fine ( Truck Moves) and I can move between the transfer gears. Link to comment Share on other sites More sharing options...
gunparts Posted December 31, 2015 Author Share Posted December 31, 2015 So I watched this on slave cylinders https://www.youtube.com/watch?v=0bW6p1eBy6w and I will check it out. and let you know what happens, thanks Link to comment Share on other sites More sharing options...
chris71 Posted January 2, 2016 Share Posted January 2, 2016 this prolly won't help much but i have an 87 with the 4.0 and ba10/5 , 2 years ago mine got stuck between first and second and i was not able to even move the truck. i ended up pulling the trans and spliting the case to find the problem ,what i found was the first second shift fork had worn the tabs off one side and ended up twisted checked the forks all had badly worn tabs . i had called around and actully found new shift forks at blumenthals (of all places ). bought them and replaced the forks along with all the bearing . after reinstalling it shifts good to this day ( oh mine is 2wd ) , and this coming march i'm swapping to ax15 and 4wd conversion . anyways that was just my experience with a stuck gear in a ba10/5 , i hope yours does not have this same problem . Link to comment Share on other sites More sharing options...
gunparts Posted January 4, 2016 Author Share Posted January 4, 2016 I looked at the brake fluids and it look full, I tried pulling the truck backwards and it is still stuck, looks like I will change it to a ax-15. Link to comment Share on other sites More sharing options...
