gunparts
    Spokane WA
  • Interests
    Moses Lake Sand Dunes And Dune Feast in Winchester Bay OR. Go Hawks.
gunparts's Achievements
  1. I looked at the brake fluids and it look full, I tried pulling the truck backwards and it is still stuck, looks like I will change it to a ax-15.
  2. So I watched this on slave cylinders https://www.youtube.com/watch?v=0bW6p1eBy6w and I will check it out. and let you know what happens, thanks
  3. I do not know how to tell if the slave is releasing or not, the clutch works fine ( Truck Moves) and I can move between the transfer gears.
  4. Thanks, and it is a 4.0,
  5. 1987 with a 5 speed manual it is stuck in 1st gear, will any transmission fit or only a 1987? and I plan to pull the truck backwards and see if it will release what do you think? Thanks
  6. I put a 2001 Dodge Intrepid Pressure Tank in with the Radiator cap and it solved all my Problems cost $10,There are a lot of Posts on this Forum about how to do it and it really works.
