Vacuum Harness Woes/ Vacuum Fitting
Hello.  Can you please help me?  I have stared at this issue for a while now.  I also have searched CC as well as online videos.
Due to a squeal, I replaced the fan belt and the idler pulley and the ac delete pulley.  To do so, I pulled out the air filter box and unconnected all the vacuum lines.  I did not label them and am having trouble figuring out which lines go together.  I have looked at that one diagram that keeps on showing up but get confused because it does not show the paths in detail.  Rather that one diagram only shows one line that comes out of the 'vacuum fitting' on the drivers side when in reality there three or four lines that are coming out of the 'vacuum fitting'.  I am not certain where any of them fit into.  It is a mess right now.  Any help would be greatly appreciated.  Thanks, Jimbo
Hello again!!  So, now I do not have 4x4....  I do not have the part-time light (which was working before I played around with the above vacuum harness project) and I do not seem to have 4x4 High.  I can tell that I do have 4x4 Low.  Does anyone know if the above vacuum harness have anything to do with the 4x4 vacuums?  I believe they are separate right?  Any thoughts on what it could be?  Thanks for your help AGAIN!  Jimbo
1988 Jeep Comanche Pioneer 4X4 4.0  93,000 miles of awesome.
