I have an 89 Comanche and the drivers side lock doesn't work right now.  When I got the car, the lock was busted.  I tried to have a lock smith fix it, and it worked for a few months, but it broke again this weekend.
My question is if I order a new lock cylinder, it won't match my glove box and passenger side right or do they set the first time you push the key in them, or will I have to get it re-keyed?
Or I might try the lock smith again and give them a second chance
Lock cylinders are set to work with keys by inserting the key and then filing the pins flush. Buy your new cylinder, then take it and your key to a locksmith. It shouldn't take him more than ten minutes to set the cylinder to work with that key.
