1992EliminatorSWB4x4 Posted December 9, 2015 Share Posted December 9, 2015 Is Moog # ES3095R the correct part number that from the drag link adjuster, the ball end that attaches to the Pitman arm, looks like a tie rod end, parts guy could not figure it out completely for my 1992 Comanche, I will replace the drag link and upgraded tie rod tomorrow I hope. Thanks. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 9, 2015 Share Posted December 9, 2015 ES3096L Link to comment Share on other sites More sharing options...
1992EliminatorSWB4x4 Posted December 9, 2015 Author Share Posted December 9, 2015 Thanks for the correct part # ES3096L. Autozone said a Duralast ES3096 should work and he just ordered that with NO "L" at the end of the part#. Do you think it will come off ok at the pittman arm with a pickle fork and big hammer or will I need a tie rod puller that has the threaded bolt in the center ? Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 9, 2015 Share Posted December 9, 2015 As clean as your truck is a pitman arm puller and a 1/2 impact should take it right off. Rent a pitman arm puller from Autozone. It is worth every penny. Plus you get the money back when you return it. Link to comment Share on other sites More sharing options...
1992EliminatorSWB4x4 Posted December 10, 2015 Author Share Posted December 10, 2015 Bo, thank you . Hang in there!!!! I will get that puller tomorrow from Autozone. Bill Link to comment Share on other sites More sharing options...
