Hi I just bought a Comanche that I have been looking for a long time because I wanted to make sure it was the right one. last it was registered was 6 years ago but runs great and was started every couple of months really has been taking care of, although the  fuses look fine none of the things are getting power, no wipers, blinkers, tail lights and almost everything that has a fuse for it in the block , the fuses are fine its just like not getting power to all of them. I did see a red wire that was added to the fuse block that was cut and led no where, maybe used for lights or something. Please any kind of help would be much appreciated
Thank You
Ps - I'm stoked to be on this forum!!
Thank You
Brown wire at the ignition switch is likely melted as well as the switch being bad.
