SBpunk Posted November 14, 2015 Share Posted November 14, 2015 So recently replaced everything brake wise. Now when I'm coming to a stop, slow or highish speed, I'm getting a banging noise. Brakes are working fine from what I can tell but not sure what it could be. Any ideas?Replaced: Drums, wheel cylinders, all hardware, shoes and worked the ebrake (after the banging) to see if it was an adjustment issue. No luck Link to comment Share on other sites More sharing options...
gogmorgo Posted November 14, 2015 Share Posted November 14, 2015 Ujoints? Link to comment Share on other sites More sharing options...
Eagle Posted November 14, 2015 Share Posted November 14, 2015 Ujoints? ^^^ What he said. Link to comment Share on other sites More sharing options...
SBpunk Posted November 14, 2015 Author Share Posted November 14, 2015 U joints were all replaced. I think the adjusters were just too lose. Some people suggested driving it in reverse and hitting the brakes a few times. It's getting better slowly. Going to take the drums off this weekend and see if anything is funny looking. It wasn't doing it prior to the brake change. Link to comment Share on other sites More sharing options...
SBpunk Posted November 14, 2015 Author Share Posted November 14, 2015 Other than that the brakes are working great. Good lockup but think I need to lower the rear load sensing valve down a bit. Since the rear was lifted up it is sitting a bit high. Link to comment Share on other sites More sharing options...
DansGreyMj Posted November 14, 2015 Share Posted November 14, 2015 Check your front caliper bolts. I had one back out and the caliper would lift up and bang the inside of the wheel upon braking while driving forward. Link to comment Share on other sites More sharing options...
SBpunk Posted November 14, 2015 Author Share Posted November 14, 2015 Funny you mention that. One of my idiot troops thought one bolt would be good enough. Caliper came up and cut his brake line. Link to comment Share on other sites More sharing options...
